Dual eSIM 2 different phone numbers
Paulv999999
I currently have a plan and an eSIM with Public Mobile but I was thinking about getting a cheaper plan with a different phone number as well with an ESIM  is that possible to do .. Because I just purchased an eSIM and it installed on my phone but it just transferred my other esim over so how would I be able to have two separate plans with the same phone? I’ve even went on my account and tried to purchase another subscription, but it wouldn’t let me
justcallmejerem
I want to do basically the same thing. I currently have an eSIM for 1 phone number with Public Mobile and a second eSIM from a different carrier with a different phone number. I use both lines simultaneously. Can I transfer the eSIM from the other company to Public mobile and still use both lines simultaneously?  I’m using an iPhone 14.
Royan
So it's possible to have 2 different Public Mobile eSIMs installed on my dual SIM iPhone 14?
I want to have a business line and a personal line on the same phone.
@Paulv999999
Remember to logout of 1st account and create a new 2nd account.
You might want to consider downloading the TextNow app for the 2nd number for free calling and texting.
Paulv999999
Oh ok yes that makes sense I guess thank you
@Paulv999999
You need to create another account using a different email address for the second eSIM.
