Drop Calls
Jantwinz7399
Has anyone experienced their phone drop calls randomly? I have reset my phone many times and it has not changed the issue.
2 REPLIES 2
Dunkman
@Jantwinz7399
Which model phone do you have?  Is it VoLTE enabled?
You may want to consider a network reset of phone. Note: this will erase any saved Wifi passwords.
HALIMACS
@Jantwinz7399
You might want to try your Public Mobile SIM card in another device to see if the problem persists.
If this issue does not happen in certain areas only, reach out to customer support and perhaps they can reprovision your account to prevent it from recurring.
  1. Use the ticketing system for a faster response time. Click here to create a support ticket, then type Customer Support Agent, then Contact Us,  or
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
