02-07-2020 02:16 PM - edited 01-05-2022 10:34 AM
i am not too sure is it a credit or I owe 63$ ?
je suis pas sure est ce que c est un crédit ou le montant je dois payer ?
02-08-2020 12:32 PM
It is a credit, and is used up first.
02-07-2020 02:29 PM - edited 02-07-2020 02:30 PM
@Lola23- Yes, you have them and can use to renew your plan and buy addons.
02-07-2020 02:21 PM
Thx you
02-07-2020 02:18 PM
@Lola23- wrote:
I am not too sure is it a credit or I owe 63 ?
je suis un peu confuse est ce que c est un crédit ou je dois payer 63$ ?
You are $63 to your credit. You have that to spend on renewals or add-ons.
02-07-2020 02:17 PM - edited 02-07-2020 02:18 PM
@Lola23- wrote:I am not too sure is it a credit or I owe 63 ?
That's a credit. It will be used to pay your plan on Feb 8. Whatever amount your plan is will be debited from that balance
