03-30-2026
07:48 PM
03-30-2026
11:20 PM
computergeek541
I have a broken display on my phone - I am trying to change my Public Mobile services from the broken phone to a working phone, however can't get the 2 factor authentication code from the broken phone to log in.
Any tips?
03-30-2026 08:15 PM
If you are using a SIM in your broken phone. Just take out the SIM and place it into another phone to get the 2FA Code.
03-30-2026 07:56 PM
Click Didn't Receive Code or Resend code, you can then choose Send email or Send Voice Message.l to get the code
With Send Voice Message, call yourself from another phone to access VM to get the code
If still cannot login, ask PM to help. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
03-30-2026 07:54 PM
Usually if you click on the option that says Didn't receive this code? There is the option to send code to your email instead.
