01-24-2021 11:02 AM - edited 01-05-2022 04:59 PM
Hello
i want to disable my voicemail but dont know how to do it. Pls help.
thanks
Tan xxx
Edit by Dunkman: removed personal information
05-28-2021 09:37 PM
@plynndy wrote:How/where/when do you key in that code to disable voicemail?
These types of commands are inputted by using the phone's dialer. Also of note is that many of these commands can be implemented from within the phone's menu system.
05-28-2021 09:10 PM
01-24-2021 12:58 PM
*004*8080000000#
This will cause all calls to either ring forever or get fast busy at the point they normally would have been diverted to the voicemail system.
##004# to undo/reset it.
01-24-2021 12:25 PM
Another way to completely disable voicemail is to change the voicemail forwarding number in your phone set it to a USA number. Since the phone can't dial USA numbers it the call is not forwarded.
Fyi I have not tried this method in a while
01-24-2021 11:21 AM - edited 01-24-2021 11:25 AM
Hi @Tanhuu
A very wise user has submitted the following as likely the best way to do this:
To return to receving inbound messages, should you wish to at a later date:
After doing this, your previous personal greeting goes back into effect automatically, and callers can leave you messages again.
(EDIT: This may be similar to what @Dunkman supplied in the above link ... ) 😉
01-24-2021 11:07 AM
Here is the help article on disabling voice mail:
https://www.publicmobile.ca/en/bc/get-help/articles/add-an-extended-absence-greeting
01-24-2021 11:04 AM
I have tried the way instructed by Google but it does not work.
