Device Compatibility | Samsung Note 9 Sm960F
yashtiwari96
I wanted to know if my cellphone with model number SM960F( Samsung note 9) is compatible with public mobile network or not
2 REPLIES 2
While the SM-N960F will work, I would consider the Canadian version, not only for better LTE frequency support, but also so that you have a manufactuer's warranty.  I know that many people do not place much value on warranty, but I would advised to compare pricing between different worldwide vesions before making a decision.
As long as that is in fact the SM-N960F and not ending with U then it should be fine.
