07-21-2021 10:48 AM - edited 01-06-2022 03:02 AM
Good morning.
When my regular data runs out will:
5GB one-time data bonus | 3458.593 / 5120 MB |
start?
Thank you,
xxxxx xxxxx
xxx-xxx-xxxx
Edit: Personal information redacted by will13am. Please do not post personal information in the public forum.
Service
07-25-2021 12:47 PM
Are you saying that it was working but isn't now? Did you set your data limiter on your phone to stop your data at your plan limit ? So it doesn't use your add on til you reset it?
07-25-2021 12:35 PM
Good morning.
- I had previously asked if my bonus data would activate when my monthly data was used up.
- It did not work.
- Please resolve or I will cancel my service.
- Thank you.
- I cannot receive your reply.
07-22-2021 04:14 AM
You have already used about two thirds of your 5gb of bonus data. Meaning on average you have been exceeding your plan data by about 500mb per 30 days (assuming you got it around the beginning of the year).You will probably fully consume the 5GB in the next 3 months or so.....
You may want to consider scheduling a change plan on next renewal to a larger data plan or you may be on an older version of one of the two newly updated plans. The $35 plan had its data increased to 2.5gb (3gb w/autopay) and the $50 had its data increased to 10gb (10.5gb w/autopay).
07-21-2021
04:06 PM
07-21-2021
04:13 PM
computergeek541
edited by computergeek541: information removed
07-21-2021 10:59 AM
@will13am : Mayhaps the name as well?
07-21-2021 10:50 AM - edited 07-21-2021 10:50 AM
@murmur , when the included data in your plan is used up, the bonus data that you are referring to will automatically start. In fact, some of that 5GB of bonus data has been used up already.
