Data
amenehsharifi
Hello. I have had my sim card for a month. Now for the second month I have a $15 plan. But my data is not working at all. Why is that?
Ameneh
@amenehsharifi
Login into your self serve account and check your data usage.
Are you on AutoPay for the additional 250Mb?
The $15 PM plan does not come with data unless you signed up for AutoPay.
HALIMACS
@amenehsharifi
Could you be out of data for your current cycle allotment?
Check under your "My Data and Add-Ons" section of your self serve account to see if there's any data left.
If nothing is showing, you've used it.
EDIT:  section looks like this:
Was the data working before or is this the first time that you've tried to use it?
