Data
KJM
We put data on our little girls phone it shows it on her account but it says no data on her phone
@KJM   which one of the suggestions worked ? Thanks..
popping
Do a simple procedure to get data working:
1.  Enable data
2.  Restart her phone with PM SIM card inserted and let PM SIM card configure the APN automatically.
3.  If not, manually configure the APN.
If she is using a LG phone, do a network reset after changing provider before data working again.
geopublic
@KJM  What phone is she using?
gblackma
Did you enable data on the phone?
Jb456
Check the APN settings they must be like below.Screenshot_20191225_182521.jpg
