Data
01-21-2020 04:36 PM - edited 01-05-2022 10:23 AM
If my data finished, can i get a plan with data only until be original olan expires?
Payment
01-21-2020 06:41 PM
Obviously, it would be wiser to just renew the current plan early despite losing current plan time rather than paying $30 for 1gb. The moderators will be needed to renew any plan early.
01-21-2020 04:41 PM
@Senaya wrote:If my data finished, can i get a plan with data only until be original olan expires?
If you have used up all your plan data, here are your options:
- Buy a data add-on
- Put sufficent funds in your account and ask Moderators to renew your plan early.
- Change your plan immediately and pay for it now.
01-21-2020 04:39 PM - edited 01-21-2020 04:40 PM
There is a data add-on for $30 for 1GB. It maybe a better option to renew your plan early or if you are using all your plan data regularly it might be time to get a plan with more data in it.
01-21-2020 04:38 PM - edited 01-21-2020 04:41 PM
@Senaya Sort of; there are data add-ons that never expire until used but are expensive. Unless you want a new plan with additional data, it's almost always cheaper to renew your current plan early. To renew early make a one time payment so that your Available Funds equal your plan cost then submit a ticket. To get a ticket click https://publicmobile.ca.ada.support/chat/ and enter your question into SIMon. Follow/invent prompts until you get to the Contact Us button, click it and a Submit Ticket button should appear.
