Data
southviewfarms3
Do i get charged if i go over my data?
When/if your data stops working, the other option to renewing your plan early or changing your plan would be to but a data add-on.  That doesn't happen automatcally as you have to tell the self serve system that you want it.
jonfirlotte
You will lose access to data until the plan is renewed.
mimmo
No. Data access just stops.
