Data
Dymndaries
Why can I not send video in a text message
2 REPLIES 2
slusagm
Make sure old sim removed or disabled
Then Reboot phone and Reset Network Settings
hi @Dymndaries
what phone are you using?
Telus (PM) has retired some legacy servers and old phones from 2017 before will be affected
and check if you have these APN settings
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
