Data
Alpine_golf44
Says I used 64 g of data when I checked usage its under 5
2 REPLIES 2
@Alpine_golf44
If you are reviewing your usage on the PM app. Swipe down on the screen to update your usage.
slusagm
@Alpine_golf44
maybe just a cache problem. Check again using browser with Incognito mode
or if you need PM to confirm, simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
