04-08-2025
01:57 PM
04-08-2025
04:23 PM
computergeek541
How is is that I can stream YouTube videos for hours, I can listen to Spotify for hours but when I listen to a podcast on the Daily Wire podcast - very conservative - my data goes straight to 95% used? It’s absolutely uncanny…literally EVERY time I use data to watch that channel it blows through my data. And I’ve tested it with other podcasts and YouTube…only when I use Daily Wite does the data get used up g super quickly!!
04-08-2025 02:21 PM
@SGimbel Are you using their App or getting it through YouTube? Looking at some Google results there are criticisms of the app with people saying it works better through YouTube.
04-08-2025 02:05 PM
what phone do you have? you have to check with your phone's data usage and check if your app really used that much of data or if some other apps used that
