06-24-2024 08:29 PM
My new cycle started on June 22. But my data has been used 100mb, I didn’t use that much
06-24-2024 09:10 PM
You can disable background updates and put your phone on Airplane mode before you go to sleep and disable when you wake up.
06-24-2024 08:38 PM
@Feiyu where you see it showing 100Mb? on your phone or My Account?
and if on your phone, you sure you turn off background data? data an drain fast if you not guard it well
