Data usage
03-30-2023 08:34 PM
03-30-2023 09:12 PM
Also try to click Reset All network and see if it resolve the issue (please note after that, you will have to re-setup your Wifi and bluetooth as well)
if nothing work, please open ticket with PM support:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
03-30-2023 08:45 PM
Hi, I have tried that but it is still not working
03-30-2023 08:39 PM
@Anum95 provide us more details
did you check My Account and confirm if you still have data left? Please login using Incognito mode to assure you are not reading local cahed info
Also, make sure you don't have Mobile data limit enabled on your device, especially if you are using Android
if you are on iOS, make sure you tried different app and the app is enabled for Mobile data on the Mobile data page
