04-10-2019 07:28 PM - edited 01-05-2022 04:17 AM
Hello,
My data suddenly stopped working. The LTE icon flashes on and off, but does not work.
SMS messages also don't send when off wifi, but do send when on wifi, which is strange.
I'm running on a Huawei P20, Android version 9, I am in Winnipeg. Plan includes 4.5gb of data and I am nowhere near running out.
I have already tried the following:
Turned phone on and off
Turned airplane mode on and off
Turned phone off and reinserted the SIM card
Reset APN settings
When sending SMS with no wifi, error message says "Can't send message with Public Mobile, error 500".
Right as I was done typing that up, my SMS started sending, but still no data.
Thanks in advance.
Phones
04-11-2019 10:06 AM
Working fine today. I guess just a local outage. Thanks!
04-10-2019 07:51 PM
@Maria_v wrote:Hello,
Reset APN settings
Thanks in advance.
Hi,
It sounds more like a network issue. You should PM the Moderator Team and ask if your area is affected by network issues.
04-10-2019 07:32 PM - edited 04-11-2019 10:19 AM
Reset APN settings
Thanks in advance.
My understanding is that their are network issues with the Telus/Koodo/PM network out West so that might be the reason you are experiencing these issues. Hopefully they solve it soon.
