Data not working
MaxKud
Hi, I switched to plan with data 2 days ago, but it's not working.
I have LG G4, set up APN according to apn-canada.gishan.net, rebooted - still no luck.
Hi can I get data working?
MaxKud
Thank you guys
only factory reset helped in my case
mimmo
If network reset does not work then a factory reset is required.
will13am
@MaxKud, there's a network reset function in the G4.  Please do the network reset, reboot, manually add back the apn.
