09-05-2018 09:12 AM - edited 01-05-2022 01:39 AM
I just moved my LG G5 over from Koodo and everything worked there. Voice and Text are fine. Wifi is fine. Just data is a problem.
Mobile data is on
apn was updated : (sp.mb.com etc)
mobile networks set to: gsm/wcdma/lte auto
LG network reset done
device restarted
Any suggestions?
Thanks
AK
Joining Public
09-05-2018 01:25 PM
Hi All,
Thanks all for the quick response. Looks like the LG G5 needs a factory reset for data to start working. 😞
AK
09-05-2018 09:56 AM - edited 09-05-2018 09:57 AM
If network reset does not work then factory reset is needed . From what I remember the factory resets we're needed more often than not with lgs. Ofcourse do every other option first.
09-05-2018 09:40 AM
@Dunkman wrote:Need to make sure that APN setting matches exactly including upper and lower caps. Maybe check the APN setting according to this website:
Ensure you have the correct APN settings by visiting https://apn-canada.gishan.net/. Select the brand and model of your phone, scroll down the page and then select Public Mobile. After doing so, you will be provided with the exact APNs required for your phone on our network.
According to website, you will might need to do a factory reset:
- If you have an LG phone and you still aren’t able to use your data after all of this, we suggest doing a factory reset of your phone.
I think network reset is sufficient. Factory reset would be like hitting a fly with a sledge hammer.
09-05-2018 09:31 AM
You need to do a network reset for your LG G5 after changing provider even you are on the same network with different provider.
Please do not perform factory reset as factory reset delete everything. Network reset only clear the network related parameters. Your LG G5 will work right away after network reset without setting up your account, contacts etc again.
09-05-2018 09:16 AM
