11-05-2025
01:31 PM
11-05-2025
07:15 PM
computergeek541
I have already subscribed but today is the last day but data is not working
edited by computergeek541: changed category label as discussion isn't related to Community
11-05-2025 01:45 PM
if you wish to renew your current plan earlier than regular renewal date, you need to get Customer Support to do that.
11-05-2025 01:35 PM
new subscription?
voice calls work? Try reboot phone and reset network settings
if that does not work, ask PM to reprovision the account for you.
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
11-05-2025 01:32 PM
I want to do now that same subscription
