Data not working
Kari2
My data shows LTE and is not working. I have plenty of 4 g data left
Janii
I had the same issue with my LTE a few weeks ago and it so happened that they were fixing the roof at my work so it’s possible, the city or where ever you are is blocking your access. I tried rebooting my phone and moving around to find a place for my LTE can work.
Bigjay83
@Kari2 Do you have a Data Limit set on your phone?
@Kari2  Have you checked the outage map
Outage map in your area:
https://istheservicedowncanada.com/
Kari2
I have done all that my account is fine. Have done everything I can think of
@Kari2  Double check like this and reboot the phone also check outages
Try again incognito/private mode
And or lap top /computer
                    OR
simply try refreshing the page to check data plan / mins / add ons
