Data is very slow or sometime not working
Tawfick
Data is very slow or not working at some point.
I need to change the service because I am an Uber driver if it is not fixed tonight.
2 REPLIES 2
johnpaul
Maybe you have consumed all your data? Check your self serve.
As an Uber driver, you may consider getting higher LTE speeds. You use your phone data for the Uber app (Uber server access, navigation, location services, payments) consistently. I am not sure if Public Mobile is appropriate for you.
GinYVR
@TawfickTry rebooting your phone.. Moderators response time takes 48 hours + so you might want to consider non Public Mobile alternatives if time is of the essence.
