08-20-2020 07:11 PM - edited 01-05-2022 12:37 PM
How do I find out how much data I have left on my account.
My Account
08-20-2020 09:54 PM
Follow the link to the login page
https://selfserve.publicmobile.ca/
Once you have logged in. Usually your email and password. It will appear if you click on the overview tab. Look for my usage
08-20-2020 07:35 PM - edited 08-20-2020 07:38 PM
What actually happened when you tried to dial 611.
That one answers even when your account is suspended
Would you be able to test your sim in different phone?
Please login into your account and click the link to change your sim, it will be on the right side under your referral code, looks more like a footnote in the profile preview.
DON'T attempt to change the sim, but check if the last digits actually match your sim. It looks like either your phone is your sim is not working properly
08-20-2020 07:31 PM
@Gracewilmal it's the overview page. The default one when you log into your self service account. Stay safe.
08-20-2020 07:30 PM - edited 08-20-2020 07:31 PM
When you login to your selfserve you will see overview page it should be listed on the left side
You will also see link to data and addons as well as usage
Everything that you still didn't use up will be showing, if it's missing it means you used it up
You can purchase more data in addon section.
You can also change your plan if it doesn't meet the needs or ask moderators to renew you early if you only have couple of days left but can't wait until renewal
08-20-2020 07:30 PM
@Gracewilmal Landing page is the main page of your self serve
08-20-2020 07:26 PM
- What is the landing page
08-20-2020 07:25 PM
611 is not answering.
08-20-2020 07:17 PM
Or go to your self serve account check data and add on usage.
08-20-2020 07:16 PM - edited 08-20-2020 07:17 PM
@Gracewilmal Access selfserve the data counter will show on the landing page. If the data counter is missing it means that you have used up all your data.
08-20-2020 07:15 PM - edited 08-20-2020 07:16 PM
@Gracewilmal call 611 press option 3 and enter your pin code
