Data add ons
10-30-2017 07:12 PM - edited 01-05-2022 03:29 AM
I accidentally bought 1000mb of USA roaming data as the page moved when I was purchasing. I was trying to get 400mb of data. I will never use the USA data I'm in Canada. Can it be changed to regular data? It cost $23 and I can't use it
Service
11-01-2017 08:50 AM
You will need to message @CS_Agent in order to get the issue fixed.
11-01-2017 02:35 AM
Is the issue fixed?
10-31-2017 10:27 PM
Just like passiveegg mentioned you will need to direct message "Moderator_Team" excluding the quotation marks as written above in order to get your US data addon reimbursed toward your account balance or towards any other add-on or plan.
10-30-2017 07:23 PM
Looks like an issue that the the moderators will have to fix. Message them your phone number and account number with the issue. @CS_Agent
