Data Usage
04-21-2017 08:19 PM - edited 01-04-2022 01:41 PM
I have the 12GB/90 days plan. A couple weeks ago I ran out of data. Thats fine I just got a couple 1GB add ons. I figured I used them really fast due to being on a work site and having to tether a computer. Those 2 instances used 1.5GB and 1.8GB respectively. Now I looked back over my data usage over the last 90 days and from the looks of it I haven't come close to the 12GB of data befor I had to get the 2 data addons.
Could someone please explain?
04-21-2017 11:17 PM
04-21-2017 10:57 PM
What phone are you using? Most phones have data usage tracking in them.
04-21-2017 09:01 PM
Oh that's already done! Learned my lesson.
Its just odd that aside from that I would still have more than 8GB of data left.
04-21-2017 08:58 PM
@tmclunn wrote:Haha yeah thats what happened.
Only as soon as Windows was connected it quietly burned through 1.5 and 1.8 GB of data doing updates.
I was looking at the data that was listed in my usage on the site here.
Don't you just love windows and their spurious updates? Anyway, with LTE data being so fast, it is pretty easy to burn a ton of usage. Make sure to set the tether connection as a metered connection.
04-21-2017 08:47 PM
04-21-2017 08:43 PM
@tmclunn, are you suggesting the data meter for the included data may run differently than for addon data? Have you tried comparing to the data meter on the phone to see if there is any discrepancy? BTW, you really got to be careful with tethering to the laptop. I recall the first time I did that with the Public Mobile service, a windows update came along and ate up over 500 megs of usage. I forgot to set my phone connection as a metered connection. Live and learn.
04-21-2017 08:25 PM - edited 04-21-2017 08:27 PM
@tmclunn, it does sound strange that you could use more data then what was purchased as it is an addon and prepaid so weird you could use more. You will have to private message a MOD and they can look into it for you a little deeper. You can find out how to message a mode here
