Data Stopped Working
04-11-2018 05:59 PM - edited 01-05-2022 04:35 AM
Hey Guys,
I maxed out my data last month, but have hit a new month, and now I can't access any data. What is going on?
I did a reset, and I also took my sim card out, and put it back in. Any help is great, because I'm paying for something that I'm not receiving.
Thanks,
EM_King
Service
04-12-2018 02:29 PM
I'm LTE all the way.
I've talked to a moderator, so hopefully, it will get resolved rather quickly.
Thanks
04-12-2018 02:24 PM
@EM_King is it an LTE plan or the 6+6 "3G"-speed plan? If you're not sure which speed data plan you have, uou can tell your data speed by clicking here. If it's a "3G" plan, you were likely affected by the bug where your data didn't reset on your last renewal and you'll need to reach out to the moderator team for assistance.
04-12-2018 02:20 PM
I still have text and calling, yeah.
I'm on a 90 day plan with 12GB, but I haven't been streaming. I would have polished that off in a month and a half, too. I'm pretty impressed with myself if that's the case.
Thanks for your help
04-12-2018 09:05 AM - edited 04-12-2018 09:06 AM
When was the renewal date. To my knowledge the renewal date is the day AFTER the payment date. Check your self-serve account to see when payment is due. For example if it's today, you're actual "new month" will start tomorrow.
GC
EDIT: Also, you said that you took out and reinserted your SIM. I assume you still have text and calling?
04-11-2018 07:31 PM
@ute1978 @will13am great replies, you've nailed the two most likely causes of this issue.
04-11-2018 07:23 PM - edited 04-11-2018 07:23 PM
@EM_KingJust out of curiosity, are you on a 30 day plan, or a 90 day plan? Because there also are some hiccups in understanding that on a 90 day plan the data is for the whole 90 days not per month.
So for example if you are on the 90 day 1.5 GB plan, the 1.5GB data will reset after 90 days not after a month.
04-11-2018 06:09 PM
@EM_King, do you happen to have a 3G data plan? Some customers do experience data counter reset issues when renewing. If your plan includes 3G data, please send a private message to the moderator team an have them look into the data counter reset to make sure there isn't a problem there. The moderator team can be reached via private message using this link. Refer to the following link for information on contacting the moderator team.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
