11-08-2019 05:33 PM - edited 01-05-2022 07:54 AM
im using a MaxWest phone i purchased from london drugs and im trying to send a message over data using an app called Signal Messenger and it isnt sending? i think it may be apn settings but im not sure what they are, and i have to drive to bc tonight please help!
11-09-2019 12:17 AM
@SilasXavier wrote:im using a MaxWest phone i purchased from london drugs and im trying to send a message over data using an app called Signal Messenger and it isnt sending? i think it may be apn settings but im not sure what they are, and i have to drive to bc tonight please help!
Nothing else on internet is working on mobile? If so, use the APNs that @GinYVR just gave you. On some phones, you have to set the APN type to default for data to work. I hope the phone isn't running Android 8.1 because of of those don't let you add APN. If other stuff works on your data connection, this isn't an APN problem but a problem with the Siganl Messenger app.
11-08-2019 05:36 PM
@SilasXavierThe APN settings can be found here APN https://apn-canada.gishan.net/en/apn/public-mobile
