Data Not Working?
04-05-2017 09:42 AM - edited 01-04-2022 01:38 PM
I recently joined Public Mobile and my data just hasn't worked even though the rest of my service is fine.
I have gone through some troubleshooting steps:
I made sure data was enabled.
I set up the APN as described in the forums here.
I power cycled following setting that up.
I tried deleting the APN and starting from scratch and power cycling again.
I tried flipping Wifi and Airplane mode on and off a few times to see if that made a difference.
I even factory reset my phone because it is an LG and I saw some folks with LG phones had to do this and the issue is still not resolved.
I definitely have data remaining because I registered a few days ago for a 90 day plan with 6gb of data and self serve confirms that and that I have used none of it.
Data has worked on the phone previously with my old carrier.
I did not port over my number, if that is relevant.
When I enable data my phone displays a 4G LTE icon at the top but doesn't indicate any activity.
The phone is a new and unlocked LG K7 that has not been having any technical issues aside from this.
Any suggestions?
Thanks in advance!
Joining Public
08-27-2018 07:49 PM
When you have the data settings on choose autautomatically the phone doesn't connect with the data server, it wants you to choose only one server.
I had the same problem on virgin but not on freedom.
04-20-2018 12:44 PM
so what was the exact issue?
04-19-2018 09:04 PM
PROBLEM SOLVED... WHAT A PAIN.
Follow instructions on this page: https://support.t-mobile.com/docs/DOC-30613
04-19-2018 07:02 PM
I have the exact same 330 k7 lg with the exact same problem... let's get this figured out.
04-14-2017 10:54 AM
Try taking the sim out and restarting the phone. It worked for me after that.
04-07-2017 11:23 PM
I would definitely try to pop your sim card in another phone to check if it is sim card/ account issue.
04-06-2017 05:01 PM
@MissRiley You certainly have a conundrum. If you have not already done so, it is time to send a moderator a private message ( @Mary_M for example) with your phone number and an explanation. This is to ensure your account has be configured correctly.
While you are waiting, you try your SIM in another unlocked phone, and someone's SIM in yours, just in case it is in fact phone related.
Also, this comment from @s2scotty related to MMS settings is worth a look:
"If you have multiple APNs listed, ONLY one, the PM one, should have the APN type "default".
Including "mms", as in, "default,mms" makes it clear TO THE PHONE to route MMS via this APN/carrier. IT APPEARS CRITICAL THAT there are NO SPACES between the words and the commas (e.g. "default,<space>mms" = wrong and "default,mms" = correct). A trailing space proved an issue on a phone (e.g. "default, mms<space>" = wrong and "default,mms" = correct). Like "default", only the correct and active APN should include the "mms" tag.
* Name: Mobile Internet
APN: sp.mb.com
Proxy: Unspecified
Port: Unspecified
Username: Unspecified
Password: Unspecified
Server: Unspecified
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Unspecified
* APN type: default,mms
* APN roaming Protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F"
04-06-2017 11:10 AM
04-06-2017 01:53 AM
https://apn-canada.gishan.net/settings/1367_15_public_mobile_apn_settings_for_lg_k7.php
And LTE band is enabled as described here?:
(Not these APN settings, just the 2g/4g part)
https://support.t-mobile.com/docs/DOC-30613#steps3
04-05-2017 08:35 PM
@MissRiley OK Here is my long checklist for troubleshooting data. If you are still stuck it would be worth the effort to send a private message to any moderator to double check your account.
And a post with more detail on how to check your phone's specs for compatibility: http://productioncommunity.publicmobile.ca/t5/Getting-Started/How-do-I-know-if-my-phone-will-work-on...
DATA NOT WORKING CHECKLIST (apologies for being to lazy to remove the items you have tried)
- connects with wifi?
- cellular data turned on?
- confirm data is included in your plan and not used up
- if dual sim use LTE/3G slot
- is it all apps that use data or just the browser not connecting?
- toggle airplane mode off/on
- remove sim for 5 minutes, then install and reboot
- go to settings, then general-profile and delete any profiles
- check network is not set to 2G; use auto, 3G, or LTE
- check for operating system updates
- APN settings correct Public Mobile
- delete current APN, and re-enter settings
- remove any VPNs
- reset all network settings; you will need to add back wifi passwords after that.
- try sim in another phone and a good sim in your phone
- LAST desperate measure when all else fails; erase all data and restore phone to factory settings
04-05-2017 06:00 PM
Glad I looked it up!
04-05-2017 05:51 PM
04-05-2017 05:34 PM
@MissRiley Look up your specific model on this website: http://willmyphonework.net. Several models of that phone are NOT compatible with Public Mobile and none are suitable for 4G/LTE.
LG K7 - Canada, Public Mobile
04-05-2017 02:06 PM
hope you will have the issue fix soon, unfortunately it is one of those things that need to be fix by PM.
04-05-2017 09:56 AM
@MissRiley, sorry to hear you are having issues. Have you logged into self serve to verify that there wasn't an error when you started your plan and making sure data was added. Other than that the best thing to do is to contact a MOD by private message. I will tag @Mary_M, you can send her a message by clicking on her name then on the send message button. She will need your phone number and if you have your sim card number handy that helps as well.
