DATA
12-07-2021 11:58 AM - edited 01-04-2022 04:55 AM
Hello,
My data is not working on my phone even though cellular data is turned on. I have paid for extra data yesterday but would like to get a reimbursement as the data still doesn't work for me. Can you please enable data on my phone?
Service
12-07-2021 09:10 PM
@hebapublic wrote:Hello,
Perform a Reset of your device's Network Settings.
iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
After this if data is still not working, check the APN settings for your device.
12-07-2021 12:10 PM - edited 12-07-2021 12:11 PM
In that case, use the chat bubble at the page bottom right corner to get a ticket for help with that from a CSA.
12-07-2021 12:09 PM
sign in to Self-Serve, to review your account, if you found at Available Funds: $$
Try To Purchase Add-Ons Using Your Self-Serve Account
To purchase Add-Ons using your Self-Serve account, follow these steps:
- Click on ‘Purchase Add- Ons’ on the Overview tab and scroll down to the Add-On calculator.
- Click the plus sign (+) to add and the minus sign (-) to remove selected Add-ons.
- When you’ve added all your desired Add-Ons, click ‘Buy Add-Ons’ or ‘Make a Payment’ below the calculator:
- You will see ‘Make a Payment’ instead of ‘Buy Add-Ons’ if there are not enough funds in your account to make the purchase.
- If you don’t have sufficient funds to purchase the Add-Ons, you will be asked to make a one-time payment equal to the price of the Add-On, less your current available funds. Click ‘Submit’, then ‘Go back’: now the button below the calculator will say ‘Buy Add-Ons’.
- Select ‘Confirm my purchase’, and you’re off to the races!
after you Add-on you have to do Rebooting your phone
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Overview Of Add-Ons visit Here link...
if you can't fix it you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to them can solve, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started. Type,, Ticket ,, Click ,, Contact Us ,, Select your issue ,,
Click here to submit a ticket↗↗.
- or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
- please include in your message,
- phone number,
- account 4 digit pin,
- Email address,
- Customer Support Agent by CS_Agent, will Response to your inbox by private message
- During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
- Monday to Sunday: 6 AM to 10 PM EST
- Note: For public mobile No Support by phone call or Email...only by CS_Agent, private message..
Good Luck...
12-07-2021 12:05 PM
I already purchased extra data but it turns out the issue is not that I didn't have enough data. The data does not work on my phone. I'm requesting Public Mobile to enable data on my phone as I have 1 GB of data each month and it's not working for me.
12-07-2021 12:03 PM
Do you still see a balance in your account ?
Purchasing an add-on is a two step process. You need to purchase the add-on.
12-07-2021 12:03 PM - edited 12-07-2021 12:07 PM
To buy a data add on, you have to deposit the money into your account first, then go back and choose the data add on that you want. It's a two step process.
Log out of your account and log back in and you should see the data add on in your account.
Then restart your phone and the data should be able for you to use.
12-07-2021 12:02 PM
Hello,
