11-28-2022 11:33 AM
Hi,
I received an sms for cyber monday which states that " Upgrade to 15GB of 4G speed data for just $40/mo".
How can i avail this.
Thanks
Plans
11-28-2022 12:42 PM
Yes, you're correct. The 15GB $40/month plan will stay at that rate, whereas the Black Friday $35/month deal only lasts for 15 months.
11-28-2022 11:54 AM
Hi, quick question about this: is the $40/month rate indefinite, i.e., it doesn't end after a few months like the Black Friday deals (which seem to be a discount only for 15 months)?
Thanks!
11-28-2022 11:46 AM
@prabhashjain Also $5 reward each / month for referring a friend for 5 months.
11-28-2022 11:40 AM
Hi @prabhashjain login to My Account, Plan & Add-ons , then click Change My Plan, it should show you all the plans, there. Click 4G speed from the 2 tabs, you should see two $40 plans, there, one is only 5GB but the other one is 15GB, pick the correct one
11-28-2022 11:35 AM - edited 11-28-2022 11:37 AM
@prabhashjainGo to your account click change my plan..find the plan you want choose to switch at your next renewal
