Current subscribers how to change eSIM to SIM card
Purita
How can I change from an eSIM to a SIM card with our current subscriptions
1 REPLY 1
hairbag1
@Purita
once you get a Public Mobile sim, log in to your account. If using the mobile app; click the Account tab...scroll down to Change Your Sim Card. In there, you'll enter the new 19 digit sim number. BOOM...you're done...(well then you install new sim of course)
