Coverage
nat1989
Hi,
Just transfered over to Public Mobile. What is the cell service coverage like?
I came from Telus, and heard Public uses their networks. Is that correct?
Doonerz
@nat1989 wrote:
Hi,
I also came from Telus and find identical coverage in my area.
Sharry19
@nat1989 YES that is correct ! PM uses Telus network.
nat1989
Thanks. I kept trying that link on my phone and it wouldnt display the map. See it on the computer now..
Lieux
Yes public mobile is Telus... for the coverage you can see it here...
https://www.publicmobile.ca/en/bc/coverage    @nat1989
Alex888
PM uses the Telus network, their coverage is the same, so you shouldn't notice any difference.
