Coverage near Strathroy
Lsparkes1
I am livingb in an area near Barrie thatb the map shows as covered but I get spotty service.   I am going to be in Strathroy and wat to stream some viseo from myb phone.   The map shows it as covered but I would like assurance that there will beb service.
@sulagok,
Look for the Bell sites as mentioned.
smp99
Telus and Koodo and PM use Bell signals for the most in eastern Cda
sulagok
Thanks for that link @will13am,
This is what i found for Stathroy, there's only Bell and Rogers Tower nearest to that town as below
sulagok
From the coverage map, you should have network at that location
will13am
Try using this site to check for tower locations.  It should provide a course indication of coverage.
https://www.ertyu.org/steven_nikkel/cancellsites.html
