Contact
Blondie48
Why can’t I phone you.  I want to upgrade my phone and I need to know how to connect it to my public mobile account.
You don’t make it easy to interact with you.
Community_QA_
you signed up to a phone company without a phone line 🤣
but open ticket with them, chatbot or message, it is as easy
but if just change phone, just pop your sim to your new phone.  That's why I love sim, physical.  you lost this freedom if you have an esim
@HALIMACS  At least we were able to cover all bases
HALIMACS
Whoa @Handy1 , we're on different wavelengths there.
I read it as the OP has a new device and simply needed to remove and reinsert their SIM card.
You saw it differently - indeed it could be that too I suppose...   🤔
@Blondie48 PM dosent sell phones anymore at this time . If you need support you need to engage them like this
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
or if your wanting to change plan do it like this in your account
Change plan in 3 easy clicks
Once you find plan you want be sure to (change on renewal )So you don’t lose money on current cycle
HALIMACS
It's simple, @Blondie48
Remove the SIM card from your existing device.
Put it in the new device (using adapters on or off to fit the SIM slot - you may not need them).   If you need to ADD adapters, try any of the local mobile shops near you as they'd have lots...
Turn the new device on.
Done
