a month ago
I just got a new Public Mobile SIM, but I can't text and only outgoing calls (sometimes).
a month ago
Turns out Public mobile gave me a phone number by mistake that someone else already had. New number-problem fixed.
Thank you all for your help!
a month ago - last edited a month ago
Your phone will require VoLTE for receiving and making calls.
Enter the IMEI of your phone to see if it is VoLTE compatible and information about VoLTE with the 3G shutdown.
https://www.publicmobile.ca/en/get-help/articles/volte
Your phone maybe too old to be compatible.
a month ago
Samsung A51
Southwestern Ontario
a month ago
Reset the Network setting on your phone and reboot your phone to see if that works.
If not then contact a CS_Agent for further help.
a month ago
@John2836 , what model of phone are you using? What part of the country are you located?
