Confirmation on bonus data
Chrisveitch6969
Got an text msg for 2gb Christmas data and responded and said 2gb would be added to my account till used and also 1gb bonus through rewards portal. I can't see on my account that I have this extra data. Thanks chris
Chrisveitch6969
Thanks for some reason my chrome browser only shows outdated info and then I tried my Samsung internet and I see all up to date info. Thanks chris
@Chrisveitch6969
Try refreshing your browser on your account.
AE_Collector
Have you texted YES2 to 4911? Some indicate it is automatically added but generally you are supposed to receive a text unviting you to reply YES2 to receive the bonus add-on.
WolverineCaz
I had the same issue. I restarted my device, used Chrome browser instead of safari and bingo it worked.
Quigley
@Chrisveitch6969
Try logging into your account using a different browser in incognito or private mode.
Your probably looking at cached information before.
Outdoorsman
@Chrisveitch6969 hi you may be looking at a cached version of your account try to log in private or incognito mode in a different browser, see if that updates your account
