Compatible with public
Mary73
Wanted to know if huawei Nova 5t is compatible with public network.  Would like to buy but can’t find it on this site, thanks
Tob1onone
 Go check on Telus network .If it works there then there is no problem with PM
NeoAnderson
One of my favorite cell compatibility sites - frequencycheck.com and your phone is there.
Mary73
Yes, I’ve checked and there’s only Nova and Nova plus, they don’t have Nova 5t
thanks
cavemantoronto
@Mary73 Direct information from the maker: https://consumer.huawei.com/en/phones/nova-5t/specs/
Yes, it's good for Public Mobile. It has 3g band 2 and band 5.
HALIMACS
Hi @Mary73
Did you try the phone compatibility phone checker?
It's here, scroll about 1/2 down page:
Get Started (publicmobile.ca)
Triguy
It should be compatible.  Make sure it is for North America.
https://m.gsmarena.com/huawei_nova_5t-9803.php
