12-23-2021 09:14 AM - edited 01-04-2022 04:51 AM
12-24-2021 01:15 PM
@BeachNBeer wrote:
Yes. I am actually using one.
@BeachNBeer as is my uncle. Okay he's not with PM but he's with Koodo, using the same Telus network. Definitely compatible.
12-23-2021 01:26 PM
Yes is will working with Public Mobile.
visit Here link to you review full information,
Public Mobile uses the following frequency bands:
- 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
- HSPA: 850 MHz, 1900 MHz (UMTS).
visit Here link, to check it all Provider in Canada about compatibility with any device..
12-23-2021 09:38 AM - edited 12-23-2021 09:39 AM
nothing better than a confirmation from one who is using it!!
@hkdennett just make sure yours is a Canadian version. If you got your A32 from another country, it might or might not work as well. Please provide use the exact model number
12-23-2021 09:23 AM - edited 12-23-2021 09:23 AM
12-23-2021 09:17 AM - edited 12-23-2021 09:22 AM
Yes it is, @hkdennett
Just make sure the device isn't locked to a carrier or was manufactured for use outside the North American Market (i e, Asian or European countries)
Also check devicechecker to ensure the device isn't blacklisted (if purchased used):
