06-27-2019 11:39 PM - edited 01-05-2022 05:37 AM
06-28-2019 04:07 AM - edited 06-28-2019 04:08 AM
@GinYVR wrote:@PrincevilleFind your location with this map https://www.ertyu.org/steven_nikkel/cancellsites.html and keep within line of sight with the Telus/cell cell phone towers and use equipment in frequencies that the cellphone towers support.. you should be fine.
Rogers is usually superior in the woods because they still support 2G... (assuming your phone supports 2G)
I'm not entirely sure that Rogers would be better in rural, remote, or forested areas because of the 2g network. The 2g network that they have has a frequecy range available in the same type of 850MHz range that is also used for 3g. Telus also has that. I'n not going to look up whether Rogers or Telus has a lower frequency in the Band 2 range, but the difference would likley be negligible.
06-27-2019 11:42 PM - edited 06-27-2019 11:45 PM
06-27-2019 11:40 PM
Active l'itinérance
