11-30-2019 05:52 PM - edited 01-05-2022 08:13 AM
Hey
I live in Ottawa, which area do I choose? I found OttawaHull, not sure if that's the right one.
I will be transferring my number from Telus anyways, but I wish to pick the most accurate temporary number for now.
Thanks,
Ed
Joining Public
12-01-2019 01:56 AM - edited 12-01-2019 01:44 PM
Just in the nick of time to get your first community reward!
To be honest, I don't recall getting a text once complete porting from TELUS either. But, it was a year ago. Maybe the text is generated once notification of the release oft he number from other carriers and TELUS isn't really another carrier so no texts are sent. Just guessing.... Porting is close to instant within TELUS companies except from Koodo prepaid.
AE_Collector
11-30-2019 10:44 PM
It's done now, no text message though.
11-30-2019 10:02 PM
Yes, my port in from TELUS took 30-60 seconds to full operation.
AE_Collector
11-30-2019 07:01 PM - edited 11-30-2019 07:02 PM
@Ed404 wrote:Hey
If you're porting in a number, it makes no difference where you take a phone number from now unless you're not going to be porting right away and people will be calling you at that temporary number. Whatever number you're using at that moment, remember that people might have to pay for long dsitance to reach you if you pick a number from a different area. As soon as you request a number port in, your temporary number will be gone anyway.
11-30-2019 06:15 PM - edited 11-30-2019 06:17 PM
Area code 613 or 343 are for Ottawa and surrounding areas. For a temp number...just make a selection as you'll be porting your old number shortly. Porting a number from Telus usually goes fast and smooth.
