07-08-2018 11:35 PM - edited 01-05-2022 05:05 AM
Hello everyone,
does anyone know know how we can check our phone number. I just got started with the sim today morning but seemed to have forgotten the number I chose, how can I check that?
01-02-2020 08:08 PM
@punith wrote:If you are using an Iphone. Please use the following steps:
1) settings
2) select 1st option like your profile which shows as (apple ID, iCloud, iTunes & appstore) below your name.
3)select 1st option which will show as ( Name, Phone Numbers, Email)
4) you will be able to see your public mobile number at (contactable at : it will display the number)
This thread, and its last post, is nearly 1.5years old, and marked as solved. So you can safely assume that the OP managed to find their phone number by now.
I realise that you are new here, but, for future reference, your energy is better used by replying to a current discussion, if you have additional, correct and relevant information.
01-02-2020 06:45 PM
1) settings
07-09-2018 12:56 AM
Hi there,
You should be able to find it under Settings->About Phone
It should be somewhere there or you may have to go to ->Status and it'll be there.
You could also go into your contacts app and your number should be in there as well.
Cheers,
Liam
07-08-2018 11:59 PM
@Ginni-Aemaan wrote:Thank you @RobertQc and @NDesai.
the About sim works in new iPhones not older ones. I have 4s.
Plan information page showed the numbe so thank you again @NDesai
You're welcome!
On iPhones, i believe you can also see your number marked as "My card" in Contacts app.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
07-08-2018 11:58 PM
If you log into your self-serve Public Mobile account, your phone number is listed within the plan details.
In addition, you could call someone and take a look at the call display information.
07-08-2018 11:53 PM
07-08-2018 11:44 PM - edited 07-08-2018 11:45 PM
Iphone.
Android
07-08-2018 11:43 PM - edited 07-08-2018 11:44 PM
@Ginni-Aemaan You can find your number either from your phone settings (usually About Sim) or place a call to your friend or any other line just to see your number. You can also login to your self-serve account and see your number on Plan information page.
