Charged twice
RobCarn
Hi I was charged for my SIM card twice. I want to know how I can get one of them refunded.
gblackma
@RobCarn what do you mean charged for you SIM twice? Thanks.  Welcome to the community. Stay safe.
RossN
@RobCarn contact a moderator  click on the ? Bottom right hand corner Ask Simon to speak to a human this will help create a ticket to speak to a moderator  mention overcharged for sim  check the envelope top right corner for a reply response time is 2 to 48 hours
iliketotalk
@RobCarn hello try contacting a moderator you can do so by clicking the question mark at the lower right corner,to avoid going around in circles with Simon say that you want a human to speak to, a ticket will then be generated briefly mention your issue, you should get a response between 2 to 48 hours a reply should show up in your little envelope in the top right corner
