10-13-2019 09:45 AM - edited 01-05-2022 07:33 AM
I had a basic plan ($10 a month) and upgraded to a higher priced plan a few months ago.
I no longer need the features of the upgraded plan.
When I click CHANGE PLAN, I can not change back to the plan that I started with. The basic plan is not in the list of plans offered.
Please help
10-22-2019 01:53 PM
get 5 of your friend to sign up that way your will pay ten dollars for a 15 dollars plan.![]()
10-13-2019 11:16 AM
@sailorboy wrote:SCAM
Plan offers so change from time to time. What can you do?
10-13-2019 10:05 AM
Hi @sailorboy
There was a panty of notice for that plan. They announced it couple of times before and brought it back. It may be back at some point again.
What I would do if I had to change temporary, the day off renewal to the new plan I would postdate it to my original plan.
10-13-2019 10:01 AM
Don't forget that if you refer people you both get $1 off. So with autopay and referring 3 people you end up paying what you used to pay. Plus the more you use the fourms the lower your plan can get.
10-13-2019 09:58 AM
@sailorboy the 15$ plan with autopay is only 13$ with more features, it's still a good cheap plan!
10-13-2019 09:58 AM
Still $15 is cheaper then what other carriers offer. Considering you get rewards on PM the plan will just get cheaper.
10-13-2019 09:51 AM
SCAM
10-13-2019 09:47 AM
@sailorboy they took out the 10$ plan last week! For now the lowest plan you can take is the 15$
