12-30-2018 08:30 PM - edited 01-05-2022 06:23 AM
If I change the email address on my account (not the community) does that automatically change my login userID?
If the the old email sticks as login, then how do you change your login ID?
Thanks
07-25-2019 08:08 PM
@AmtulYou would need to contac the moderators to change your email as email address is the index for the Public Mobile's database.. you can contact them here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-25-2019 08:00 PM - last edited on 07-25-2019 08:12 PM by computergeek541
Hi my name is yahya and I want to change my email address. my phone number is 1-xxxxxxxxxxxxxx
Phone number removed by computergeek541
12-30-2018 11:45 PM - edited 12-30-2018 11:47 PM
when you go to your account then My Profile >>> Change Username, you enter the New Username (Email) and click “Change” and you’re finished. 😉
12-30-2018 08:36 PM - edited 12-31-2018 09:55 AM
Yes, that changes the email address for logging into your account.
However, the "true" account email address is not changed unless you make a request of the moderators. It's another odd system limitation; in effect the original email address used to create the account cannot be changed by the customer.
