03-14-2025 03:31 PM
I want to change my subscription to the new 29.00 can-us-mex plan from a 35.00 can-us plan but its not offering it as an option. How do I subscribe to the new plan
03-14-2025 07:23 PM
If I go to change my plan, either in the mobile app or on the website, it's only showing me Canada-Wide or Canada/US plans. I already have a Canada/Mexico/US plan, but apparently, I can no longer change to any of the other Canada/Mexico/US plans. If I want to change my plan now, I can only go to Canada-Wide or Canada/US. 👎
03-14-2025 06:39 PM
It is possible to downgrade., you just don't see all the plans
03-14-2025 06:32 PM
I wouldn't say that is always the case, but most of promotions are for new customers only and then it is not possible to downgrade..
03-14-2025 04:21 PM
Unfortunately, PM has made it impossible for existing members to downgrade to a lower priced plan.
Your only option is to port out to another carrier and port back as a new member but this is a big hassle.
03-14-2025 03:34 PM
Sorry, if its not allowing you to change to it when you sign into your account and click Manage Subscription, that means you can't get it. That's for new subscribers only.
