03-11-2022
03:11 PM
03-11-2022
05:18 PM
computergeek541
03-11-2022 05:42 PM - edited 03-11-2022 08:57 PM
@Heatherlaboss I doubt there are much you can do if you got from Kijiji. The most Kijiji will do would be to ban the seller but they won't provide refund.
of course you can try to contact the seller but we all know of it will work.
I guess you have to be more careful and buy it from trusted source next time
03-11-2022 05:18 PM - edited 03-11-2022 05:19 PM
@Heatherlaboss wrote:New problem it's black listed I bought it a year ago from kiijiji . What do I do now?
There isn't a lot you can do but try to get a refund from the seller for the price you paid for the phone. You're going to need to buy a new one.
03-11-2022 03:30 PM
03-11-2022 03:25 PM
@Heatherlaboss ok after device check with the link above?
if so, tell me what was the error showing on the screen.
03-11-2022 03:23 PM
I had an iphone and bought a Google pixel 2xl I don't have the other device to see if the sim works no other active sim
03-11-2022 03:17 PM - edited 03-11-2022 03:19 PM
@Heatherlaboss does the sim still work on the old device? where you got your new phone from? from trusted source? check if the phone is blacklisted, just in case:
https://www.devicecheck.ca/check-status-device-canada/
also, if you have another active SIM, put it in to confirm the phone works
and what brand and model is your new phone?
![](/skins/images/34AB3B0FE78BBE11DBF186F131BC3766/responsive_peak/images/icon_anonymous_message.png)
