09-04-2018 06:14 PM - edited 01-05-2022 01:39 AM
Where can I change this setting? I'm guessing I didn't get the Koodo email as I may have said 'no' to this when I set up my account, and I can't see it anywhere in self serve/profile.
Thank you!
09-04-2018 09:13 PM
Daughter is currently on the 2gb LTE/$45 plan, but I've changed it to the 8gb 3G/$50 plan starting Sept. 6th.
09-04-2018 09:10 PM
@Anonymous wrote:@SideshowBob, *IF* you have opted out from promotional messages from Public Mobile, I don't think there is a way to get them back. I think there is a way to send a text and the reply will tell you if you are eligible for any offers. If that's not what you are talking about, please advise...
Edit: Only thing you can do is text "offer" to 5130 or 5129. If you are qualified for any offers, you will get a reply back.
Manually checking for offers is a bit of a lottery. I have seen Public Mobile send offer type information from a number of sources. This time it was 5130. Previously it was 5132. I have switched phone a few times along the way, I recall receiving messages from other 51xx numbers. Good luck figuring out what number they will use next.
09-04-2018 09:09 PM
@SideshowBob wrote:Yeah, I did another search and found similar posts. Seems a weird thing that they can't reset it.
You may not be getting them because not everyone does. They are targeted offers. What plan are you currently on?
09-04-2018 09:06 PM
09-04-2018 09:05 PM
@SideshowBob wrote:. . .
Edit: I shall tag a moderator to see if they have any idea.@moderator_team, I summon you!
@SideshowBob, I don't think your tag took. Should appear as a link. That said, many have asked in the past, I don't hink even the moderators can reset it. There are several posts discussing this issue.
09-04-2018 06:23 PM - edited 09-04-2018 06:27 PM
You'd think that would be an allowable change, hopefully someone @ PM can check.
When my daughter gets back from her 1st day at high school (poor blighter) I'll see if texting that # will return anything.
Thanks!
09-04-2018 06:20 PM - edited 09-04-2018 06:21 PM
09-04-2018 06:20 PM
Good question @SideshowBob! I don't know the answer, but PM should have a privacy officer... if not PM, at least at Telus. Maybe one of the oracles knows the answer...
