Change plan
Kash1987
Like to change to 25 dollar half gb plan
2 REPLIES 2
@Kash1987 ,
I think @RosieR has you fully covered.
I suggest to make the plan change in your account sooner rather than later (BUT better to Change on Next Renewal as already paid funds are not prorated).
IF Public Mobile follows through with these plan changes the $25 Canada Wide may not be available much longer:
https://productioncommunity.publicmobile.ca/t5/Announcements/New-Province-Wide-Calling-Plans-Limited...
RosieR
Hi @Kash1987 log in your self serve account here https://selfserve.publicmobile.ca/
>> click Change Plans
>> make sure you have enough funds to cover your new plan
FYI, there are two $25 plans , one unlimited Provincial-wide minutes and the other unlimited Canada-wide minutes.  Choose the unlimited Canada-wide minutes as that is the old $25 plan and on sale right now which is a better deal.
You will be given two options:  Change plan now or Change plan on next renewal.
Please note that if you choose to change plans now, this warning will pop up, warning you that this change will take effect immediately and any remaining time in your old plan will be lost.
It is recommended that you choose to change your plan on next renewal, but it is up to you.
I hope this helps
RosieR
