09-27-2021 09:21 PM - edited 01-06-2022 03:38 AM
I suspended my plan for 2 1/2 months.
Before reactivating the plan I wanted to change it. The payment page did not allow me to do so
The screen page demanded full payment for the plan at this I cannot use.
I wanted to change the plan to reduce my costs
09-27-2021 10:16 PM
@a8610 wrote:Nothing worked.
The account was suspended for 2 1/2 months.
When I tried to change plans before making a payment, the screen page said there was not enough dollars in the account.
I tried to pay the new plan change cost, but it kept saying there was not enough dollars in the account.
Only after I paid the 3 months to December 2021 did it allow me to change the plan.
My personal opinion, we should be able to change the plan before making a full payment on the plan that is not needed
It supposed to do exactly that as mentioned below:
"all features from your current plan will be lost and the plan change will be completed, even if you do not make a payment in the second step."
May be you having a 90 days plan causing some issues. Since you now already change it, you will need to contact CS Agents and see if they can make the change you wanted.
Here’s when and how to contact our Customer Support Agents:
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
09-27-2021 10:07 PM
Nothing worked.
09-27-2021 09:41 PM
@a8610 You should be able to do it from your account. Try using incognito/private browsing mode. Below is some info on how to do it while suspended.
Change your Plan (publicmobile.ca)
