12-12-2020 12:36 AM - edited 01-05-2022 04:27 PM
Hello
How do I change the email address I use for both my Public account and the community?
Thank you, Kat
12-30-2020 02:52 PM
Thank you! Done!
12-12-2020 02:22 AM
@Freedom55 for self serve I would change your user name first then contact mods and insist that you want all Occurances of your old email changed. They often do not understand what people want done.
As a test run the lost password feature and confirm the reset email is going to the correct address.
12-12-2020 12:38 AM - edited 12-12-2020 12:41 AM
@Freedom55 , you need to contact the moderator team to have the self serve account email address changed. Click on the chat symbol on the lower right corner of the web page to initiate a support ticket. The community account email you can do the change yourself. Click on your avatar on the upper right corner and select my settings. You should see the email address change option.
